It's like the picture at the beginning of the post ?That could work, but why not simply use two resistors?
Of course, this is most likely the case.... Because the U47 way of biasing the tube is "magical", and was in no way implemented as a technological compromise in order to simplify the power supply and cabling?
Tungsten filament life goes down very rapidly as voltage is increased. In typical tube mikes with under-voltage filaments, tubes can last many decades - this is not a bad thing.And if you increase the heating voltage and bring it closer to the standard 6.3V?
Yes, but we are talking about the fact that the filament was no more than 6.3V.Tungsten filament life goes down very rapidly as voltage is increased. In typical tube mikes with under-voltage filaments, tubes can last many decades - this is not a bad thing.
