just.sounds
Active member
So after a symetrical fet and a la3a i want to sink my teeth in a TAB V73B limiter. And found some good docu on Kubarth's page
http://audio.kubarth.com/rundfunk/index.cgi
As trafo's are still a bit mysterious to me so i'm asking for your help to select the right input, interstage and output trafo.
They are labeled 1:1 T188 Wich looks like a centre tapped and shielded 1:1 trafo. And i was thinking maybe something like a lundahl 1540 would do the trick.
And there is also the output 10:1 CTV 72/2 and i'm searching for something that works there. I can't find any impedances for those trafo's.
Could anyone shed some light on this iron?
Kind regards
Boy Griffioen
Kind regards
Boy Griffioen
