I have a Series 1E console 12x8. It's around a late '84/early '85 build. It has a TPS-05 power supply that I just recapped. Also, gave the PSU a good cleaning and even reapplied thermal compound to the bridge rectifier bolted to the front panel and the power transistors bolted to the heatsink and even replaced the two MV5753 LEDs.
Here are some pics:
So after completing all that, I checked the voltages and I get -17.94V and 18.06V for the +/-18, 48.0V for the phantom. So far so good.
However, I get 40.5V on the unregulated ("AUX" on the PCB). The TPS-05 (8510181) schematic shows a note for that rail as "+30 UNREGULATED":
Not sure if there's a problem with my PSU (I'm doing my checks before plugging into my console and potentially damage something) or if I am misunderstanding the note on the schematic.
Perhaps that note on the schematic means that rail is unregulated and when plugged in with the load of the meters/LEDs, the voltage will (should) be at around 30V.
Or is there a problem with my PSU?
Chris
Here are some pics:
Chris
