CharlesASD
Member
- Joined
- May 27, 2015
- Messages
- 7
One way or another I ended up with this transformer, and I am confused by its windings. I know it came out of a tube amp, possibly a Heathkit, but didn't see how it was hooked up. I might even be wrong in thinking that it is a power transformer, ha.
A bridge rectifier gives me way too much voltage, but a two-phase would be about right, except of course that the transformer dosn't have a center tap. I have made an artificial center tap for a heater transformer with two 220ohm resistors before, but with this situation that would waste a lot of current, right?
If an artificial ground is the right way to go, how large of a resistor can I use? Is there another device or scheme that would be more appropriate?
Mostly I am just puzzled by what this transformer is supposed to be used for. I might be going in the wrong direction. Thanks for any help!
