Slightly O/T but I'm always looking for a meter IC that does more than 30dB of range! When doing the Green pre, I opted for a design that used an LM339 quad comparator to get more than 50dB of range. This turned out to be rather more complex than I initially wanted (about 40% of the board is meter circuitry) but I could not find a chip that came close.
My thoughts are to make the top LED peak at +20 dB which is a common max level for a lot of DAW's today. The lowest LED should light at -30dB, really a "signal present" indicator.
The Hamptone comp uses a PIC for the meter, but there are no markings on the front panel, so I could not see the range. Is this a viable alternative method to get greater range than the LM3914/5/6 stalwarts?
Peter
