sbeach
Active member
I have two 24v AC transformers & I need to wire them in series to use as a single 48v, center-tapped transformer for a particular project. The secondary wiring is easy to figure but I'm a bit unsure about how best to wire the two primaries to work together correctly. I assume the primaries should be wired in parallel but wonder if one of the primaries should be reversed polarity. Can anyone shed some light on this? Thanks,
Skip Beach
Skip Beach
