Hi All,
I have a TAB V376 on the bench that's turning into what I call a "bench bomb", that is; a piece that starts taking up so much time it becomes my problem instead of my client's problem. This one came in with two others for a re-cap and check-over. So far, I've corrected at least three faults: Intermittent- broken trace on input transformer, no gain trim - bad pot, no 140 Hz LPF - wire broken off at switch (although the wire was so stiff from age that it was just hovering over the switch contact like it was still soldered ). I also had to replace at least one transistor. So, now it works perfectly, but only at the higher gain (really lower attenuation) settings, 40 to 70 dB. Below that, 0 to 34 dB, it's motor-boating. These are the first 376's I've worked on, so if you've had experience with these, I welcome your input. One other note, on these cards, all of the active components are on sub-boards, and I've been able to rule those out by trying them in the other two modules (both 100% now), so it would seem like the issue is on the main board...
