Hey guys,
After reading about the V475-2 15Khz filter section, it dawned on me that there is a inductor in the output stage of the V672 that I never could figure out the reason for. So, I tried the 'short it out' method with a switch so I could listen as well as see on my test gear. Interesting. With the inductor in circuit the top end rolls off just over 20Khz, with it shorted out, the -3dB point is around 240Khz (output loaded 600 ohms). My scope was in the car, so I did not look at the waveform, could be crap. Has anyone else messed with this? The inductor is followed by a 820pF polystyrene cap to ground. I didn't do enough listening to see if this removed the mid range bump that the V672 has, but maybe this would be a cool switch to add...
Tim
Tim
