V76 gives pfwiieeeeeeeet sound at startup :)
andre tchmil
land of chicon
Hi, one of my V76 preamps gives a Pfwiieeeeeeeet sound for about a second, 30 sec after startup :green:
after that the preamp performs just as excellent as my other one ( so comparison is easy ) for the rest of the day.
what component could causes that ??
i would suspect a dodgy capacitor or bad solderjoint, most likely caps.
Your V76 will never get over this, send it to me, you've got my address :grin:
does it changes when you manually touch the components? uim, i mean low voltages here!
good luck hunting the problem,
Tony
does kinda sound like a dodgy cap charging up if its a constant time the the noise occurs. doesn't v76 have built in psu? check the big caps in the psu.
I replaced all the caps recently with high spec. ones.
Maybe I overlooked something, will look at it again.
Tony, thanks for the kind words,
If I ever cosider to let them go .........
does it do it with or without a mic attached? some of my pres do this with certain mics hooked up as the phantom charges.
This rings a bell - even with the specific channels muted I hear that sound when turning phantom off. The channels I'm talking about are not exactly V76-like, but anyway, yes, so, perhaps - something phantom related are your side ?
It does with or without a microphone connected.
It sounds like an old Star Wars shooter. from 1khz down to around 80hz for about 4 secs.
Good to start the day with cleaned ears , I must say
:green:
