skal1
What is the safest and accurest method to measure plate current usage at a op tx or at the plate load resister.
cheers
skal1
cheers
skal1
CJ said:you can also carefully hook an ammeter across the output,
one lead on the red wire, one on the blu, fire it up,
the current takes the path of least resistance which is the ammeter,
won't this short out the tube?
no, the tube is biased to conduct a certain amount of current,
measuring across the output will not mess up the bias, so the tube will put out as much current as it normally does when going thru the output,
note that the meter leads will be at high voltage so take the normal precautions,
the beauty of this method is that you do not have to unsolder the output transformer lead to get the meter in series,
full props going out to Gerald Weber for teaching me this trick in his books,
