thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
I’ve got an LC-based EQ on the bench which has a 24v discrete front-end and a valve output-stage with 280v HT supply and unregulated DC heaters.
It has an annoying 100Hz hum…. It’s ok with the music playing, but if 0dB is the peak, it would be around -60dB…
I’ve looked for ripple on the DC rails and they’re clean-as-a-whistle, which leads me to suspect a local ground loop…
Having an outboard PSU on a valve design is obviously more complex than keeping the PSU internal, so are there any obvious faults that you reckon might exist here? As a rule, I have always found solid-state designs to be quieter with external supplies, but for valve gear, I can’t think of too many precedents for outboard supplies…
The heaters are DC, via a raw unregulated supply (secondary – to - bridge rectifier – to - filter cap – that’s it).
I’ve tried powering the heaters from a bench supply and it makes no difference.
Obviously, the PSU case and EQ case are grounded. The head unit gets its chassis ground from the tag on a 5-pin XLR, which gets its ground from a tag on the PSU’s case also connected to mains inlet’s ground. I’ve taken resistance measurements between all chassis points and main GND – no issue there.
Any suggestions?
Many thanks in advance.
Justin
Any suggestions?
Justin
