Swedish Chef
Sorry to be a bind!
I read a post the other day about the effect (on the o/p stage of a valve power amp) of changing the impedence of the speaker without the turns ratio of the tx. I think PRR wrote it. I am trying to work through how it would effect the o/p tx in particular if, for example, you ran an 8ohm speaker on the 4 or 16ohm taps. I guess if you ran the 8 on the 16ohm tap the o/p stage would be under-loaded (is that a word?) but would the tx suffer? Obviously it is dependant on the spec of the tx...
Anyhow could someone point me to the thread as I don't seem to be able to find it with the 'search' function.
chef
chef
