Vari-Mu compressor Sidechain/Detector explained
StarTrucker
GDIY Supporter
Nashville
Please school me on this, as there are mythical posts around here explaining the theory but I can't find the whole explanation in one place. Hopefully this will help other noobs like myself
This is my understanding of the "usual suspect" 6AL5 sidechain/detector circuit, a-la Sta-level, Rs124, Alter 436, UA 175/6 etc.
1. Blocking caps take only AC from the plates of the output tubes
2. the 6AL5 rectifier produces a DC signal that will be applied to the grids of our vari-mu tubes. More signal on the cathodes means more DC output to the grids and therefore more compression. ***Why are voltage readings on a meter actually lower with faster speeds, not enough time to charge back up? ***
3. The threshold network sets the DC operating point of the 6AL5 (220k resistors off cathodes). More DC means we need more signal from our output section to overcome the bias and begin compression. Less DC on the cathodes here means every little sound from the output tubes will be passed through to the time circuit, and we will get a higher ratio (more compression) for the louder parts.
4. Before our signal reaches the grids of the input tubes, this DC signal passes through the time circuit
4. The attack resistor controls the rate at which the capacitor charges
5. The capacitor controls the amount of voltage on the grids of the vari-mu tubes, A larger capacitor will take larger to charge, meaning slower attack AND release
6. The resistor in parallel to the cap determines the rate at which the voltage is drained out of the cap, called release
7. The signal is fed into the grids of our vari-mu tubes, the higher the DC voltage from our sidechain, the more compression (gain reduction) we will get.
What I don't understand is how the AC and DC interact in the sidechain. It's DC coming out of the 6AL5, but this DC swings from a steady 25ish volts down to 6ish in proportion to the output tube signal on the cathodes, making it AC right? Why wouldn't the SC cap dump all the AC swing right away, and the Release resistor dump the DC immediately, resulting in 0V coming out of the side-chain at any given time? With 0 volts coming out of the detector wouldn't it result in no compression?
If shrinking all the time values results in distortion, would adding a second 6al5 in parallel with the first offer more current to be able to refill the cap fast enough to lower distortionR.bd94e8b37e242a7bed3005d34ad0e82b.jpeg?
It's rectified, but it's not 'smooth' DC.
but this DC swings, making it AC right?
It's just a rectified version of the audio signal. Mathematically this can be regarded as a DC average plus an AC component.
Because the release resistor is much larger than the attack resistor. Current can flow into the cap fairly quickly, but it can only drain out slowly, so the cap fills up on average. Like turning the water fully on into into a bathtub, while it can only drain out through a much smaller hole. The bathtub will fill up as long as the input rate is greater than the output rate.
It's the same concept as a power supply rectifier and capacitor -see image. In the compressor it's rectifying negative voltages of course, but its the same fundamental process.
I assume you're talking about CV feedthrough distortion. Mainly it's the relative difference between attack time and release time that is the problem. The smaller the difference (e.g. you reduce the release time, or increase the attack time), the more 'ripple' is left on the cap, which is what causes the distortion. There are ways to improve this, but they're not as trivial as 'just use a better diode'. You need to understand the basics before wading into those waters!
Never considered it as a replicate of a power supply rectifier circuit. It seemed somehow special and mysterious that the "sidechain" should be more complicated where components don't work as they normally do in something fundamental like a PSU.
Thank you for de-mystifying this!
