Snatchman
Hello..Is there a build for a good passive variable line level attenuator ..?
It depends greatly on what you want to use it for and what the min / max attenuation is. Every attenuator has a characteristic impedance. So the source will see a certain load impedance and the load will see a certain source impedance. If you need the load and source to appear constant, you would need a bridged H attenuator which requires a three section variable resistor with specific values. For that you might find a Daven attenuator on Ebay but ones with a lot of steps and the right impedances are usually pretty expensive. If the load is truly balanced, like a transformer or active like a THAT 120x, then you could get away with just a simple pot across the lines. But again, every passive attenuator is going to present a source impedance that must be considered. For example, in this last case, you would not want your pot to be more than 5K or so if the cable is vaguely long. If it's unshielded, any series resistance could be a problem.Hello..Is there a build for a good passive variable line level attenuator ..?
Hello..Ian...Yes, I'd like to have it continuous...Thanks...Do you want it stepped or continuous?
Hello..Thanks for your reply..I'm wanting something to put behind my pres that doesn't have an output fader to control level going to DAW...Cables not long ( 3 ft'ish)...It depends greatly on what you want to use it for and what the min / max attenuation is. Every attenuator has a characteristic impedance. So the source will see a certain load impedance and the load will see a certain source impedance. If you need the load and source to appear constant, you would need a bridged H attenuator which requires a three section variable resistor with specific values. For that you might find a Daven attenuator on Ebay but ones with a lot of steps and the right impedances are usually pretty expensive. If the load is truly balanced, like a transformer or active like a THAT 120x, then you could get away with just a simple pot across the lines. But again, every passive attenuator is going to present a source impedance that must be considered. For example, in this last case, you would not want your pot to be more than 5K or so if the cable is vaguely long. If it's unshielded, any series resistance could be a problem.
So again, state the requirements. What are the load and source impedances, attenuation range, how long is the cable, is it shielded, is the load balanced or single-ended, ...
For this I would just make a cable with a fixed pad on the digital interface end. Just a U pad using resistors soldered directly to the jack. You should be able to make it fit inside the shell.Hello..Thanks for your reply..I'm wanting something to put behind my pres that doesn't have an output fader to control level going to DAW...Cables not long ( 3 ft'ish)...
