ok i redrew the schematic, there might be a few resistors that are off because they were hard to read, but i think everything is pretty close,
left off the Casady mods, and drew the speakers without the 5 pin jack as it was very confusing,
this amp uses an 8 inch and 12 inch speaker, do not know if the Utah spk numbers are correct so i left them out, looks like they added line outs for a power amp, possibly a big Macintosh amp for stage use since this guy is only good for about 30 watts,
it uses 7591 power tubes, which were used in some Fischer stereo amps,
looks like they have a pi filter on the bass speaker,
calculations for a
50 uf - 14 mH - 50 uf
pi filter look is 270 hz is the center frequency, phase angle will be 180 degrees at this freq if i have the filter right,
looks like Casady's amp was modified to combine both channels into the 12 inch only, he probably blew up the 8 inch,
here is the schematic, let me know if you spot any errors, have not built the amp yet so schematic is not verified>
