Hi!
I just built myself variable hv psu for experiments with tube preamps, schematic is here:
http://www.geocities.com/tjacodesign/300vsup/300vsup.html
It works very well, specially part with short circuit protection
Now i would like to understand this circuit a little better and add something that would make it work as a regulator.
I don't understand what is the purpose of fet here. Is it there only to make psu variable or it adds some regulation too?
Also, heatsink on fet is small piece of 2mm aluminium (5x8cm) which i got from old tv where it was used as a heatsink too. It gets quite hot, dissipation from fet is around 5W (300V/15mA). Should i change heatsink to something bigger?
Also, at the moment i only have one 150u cap, as on schematic. Do i need more capacitance to make ripple lower? And should i put it near C1 or at the end of circuit?
I managed to find another schematic where the same fet is also wired as a source follower:
http://www.welbornelabs.com/ps3.htm
Is it possible to add zeners to my existing psu in a simple way? Or can i do anything else to make it work as a regulator? I know, i could use something like G9's psu but i don't want to use low voltage ic-s for hv experiments. I would also like to keep it simple because i never use pcbs for tubes..
Yeah, i'm asking a lot. If i at least get responses to first part of this post, it would help me a lot.
Miha
Miha
