telehumbucker
The red peak meter lights on my 70's board went dark, apparently all
at once a couple of months ago. The meters work, just the red peak
lights aren't lighting up. Each meter has two opamps as can be
seen in the attached picture. I pulled a couple of the opamps out
and the legs are discolored, oxidized....but as said, the meters do work.
Is it possible that one or both of the op amps at each meter could affect the
peak lights? If one meter light goes out, due to the op amps or some other reason, could that render the rest of the peak lights inoperable?
