VP312 transformer experiments
TheJames
I've recently taken a VP312 preamp and outfitted it with four different transformers:
Cinemag CMMI-8pca input
Ed Anderson 2622 input
Profile 4804 output
Ed Anderson 2503 output
For swapping the input transformers, the zobel capacitors were swapped, 220pf for EA2622, and 22pf for Cinemag.
I ran frequency sweeps for the following four combinations:
1.  Cinemag in / Profile out
2.  EA2622 in / Profile out
3.  Cinemag in / EA2503 out
4.  EA2622 in / EA2503 out
For the most part these all measured the same.  All of the combinations tilted upwards to about 4k, leveled off to about 8k, then started a gradual slope down.  The one standout was the EA2622/EA2503 combination.  Where all other combinations hit 4k and leveled off, the all EA setup continued to rise up to a peak at about 16k.
What has me a little puzzled is this:
Combo 1,  pretty flat and extended response.
Combo 2, slightly less bottom and top rolls off sooner/faster.
Combo 3, pretty much identical to Combo 1.
Combo 4, slight boost in HF.
I'm having a hard time wrapping my head around why the EA2622/EA2503 combination produces the most HF.  The EA2622/Profile combination rolled off earlier than the Cinemag/Profile combination (note EA2622 less HF).  So if the EA2622/Profile combo rolls off early, and the EA2622/EA2503 has extended HF, then the Cinemag/EA2503 combination should have the most HF.  In reality though, that combination showed no difference compared to the Cinemag/Profile combination.
Granted, this is mainly academic and I would be perfectly happy using any of these combinations.  We're not talking major differences...At most a 0.5db spread, but it did surprise me somewhat.  Any thoughts on why I'm seeing what I'm seeing?
try sweeping the transformers out of circuit with no networks, just open sec.
repeat in circuit tests with  no networks also,
