Deepdark
Hi there.
I just finished an la2a nd took this vumeter on ebay: http://www.ebay.ca/itm/321236001999?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
It's rated 500mcroamp. I strap it as the schematic without caring of the rating of the vu meter. I can adjust the gain reduction 0 withing ghe 1M trimmer, but output +4 and +10 don't sit to 0 when injected signal, even a really strong one, it will move a little and if i exeed, in exemple, +4db, then the needle became crazy.
What ut tells me us that the meter may not be to read 1.228v at 600ohm through an external 3k6 resistor. Am i right? I guess i would have to test different external resistors value to get 0 at 1.228v? My output is terminated with an 680r across pin 2 and 3.
Thanks guys
Thanks guys
