owel
So, I'm using Eagle to design PCBs. They have a free version and as long as the project can fit on a 4x3 PCB, I'll be okay.
First I layout the schematic... while laying out the schematic, I have to pick the component type/dimension/package from the hundreds of options available. TO-92, TO-3, To-220 packages are no problems. They're standard.
But resistors and capacitors, this is where I get tripped. Sometimes I would pick a component that's too big that when it came to the board design, I see my supposedly 1/4w resistor is sized as a 1W resistor. I picked the wrong part! Of course, in the schematic editor you can't tell it's the wrong part/package. You just see the symbol. The part names do not come with 1/4w or 1/2w designations.
So lately, what I've done is everytime I pick a new component in my schematic, say 470uf/50V capacitor, I go to digikey.com, look for it, open the PDF, get the lead spacings in millimeters, go back to Eagle, pick a capacitor with the right lead spacings (or bigger).
Well, it takes a long time just to insert one capacitor. (The payoff is when I etch and drill the PCB, the lead spacings are exact.)
Anyways, my question is "Is there an easier way? Is there a trick? Are there cheat sheets I can use? Am I doing it right, or am I making it more difficult because I don't know something about the software?"
Owel
Owel
