I picked up this weird Oktava MKE-15 mic recently which came with a phantom power supply.
Anyway, I've got a couple of questions regarding the P/S. They are very (embarrassingly) simple.
There is no plug on the power supply. Guess what - I would like to put a plug on it. There is a two core cable coming from the unit. Despite not being insulated, I would imagine that the unit is supposed to be used with just +/- connections.
Now, I've tried to follow the wiring to see where each of the two wire go, but I can't define which should be + and which should be -.
Is there a simple way to tell? I can't tell the polarity of the P/S transformer secondary compared to the primary - just 4 brown wires!
My next question; how can I tell which socket is the input and which is the output? Both sockets are wired in parallel - this seems a little strange to me - it would mean that it doesn't matter which way round, despite the different labels on the housing.
Finally, I was thinking that it might be a nice idea to add an earth connection to ground the case. After looking in the box, I noticed that the case was wired to a diode on one of the circuit boards - I don't know why. Should I just leave the case floating then?
Roddy
[/img]
Roddy
