Kid Squid
Hi Chaps,
Just wondering if any of you could shed some light on some questions I have regarding a Westrex RA-1479C power supply.
One of my close friends inherited a Westrex RA-1593A Compressor, and the power supply for this is a Westrex 1479C PSU ( sharing same 'modular' chassis)
Since he's had it, its never worked, as previously the power transformer suffered a meltdown. ( quite possibly tried on 240V instead of 110V..)
Transformer markings are - TE 4851 DP
https://photos.app.goo.gl/ADgT9s82qeoGcYu57
and this sharpie'd on
https://photos.app.goo.gl/9pk2CJALdvyYaEbn6
Actual unit
https://photos.app.goo.gl/7FA65eAaQLY2giJRA
(I've just swapped over to google pic, but cant Share actual images ??)
He asked me to go over the units, re-cap etc, and see if I could either get the transformer rewound, or get a replacement unit.
I've got around to having a look at the PSU, found the correct schematics, and it is a variable regulated power supply.
However,
I'm a little stuck with trying to work out whats going on, specifically what would be the secondary AC volts pre-rectified / regulated value ( the variable supply has thrown me a little !).
As far as I can see (please correct me if I am wrong), that it is a 'degenerative' regulated supply, with the 6AQ5 acting as the pass element, then sort of identifying and comparing the other circuit blocks against a discrete SS regulator - error amp, reference Volts (0A2), comparison amp etc.
From the RA-1593A manual, it states that B+ is 275VDC @ 44mA, and the valves require DC - 1.2A @ 12.6V.
Also, there is another winding supplying raw AC for the power supply module heaters, but the centre tap of this winding is brought out to the terminal strip and is marked 'filament' bias. ( I will check later where exactly this is going).
Granted, that the variable output was such, that this power supply module could be used with other Westrex kit, such as the 1474 amplifiers (EDIT- just checked the 1474 schematic and it shares the same power rails..)
Maybe the variable element is just a rough trim ??
6X4 rectifier - tube drop , Ib =70mA (22V each plate) feeding a CLC filter ( 4uF caps are around top limit of max capacitance 'seen')
0A2 regulator - mean stabilised volts - 150V, Imin - 5mA, Imax - 30mA, Vreg 6V ?, striking volts - 185V
Choke input Full wave - AC volts x 1.414 = DC
B+ DC =275V ( minus 6X4 voltdrops)
AC= (275 + 44) / 1.414 = 225.6V, not taking into account the variable supply, or even if these calcs are correct !!! :-\
;D
Anyway, heres the schematic, very interested to see what you chaps make of it.
https://photos.app.goo.gl/Q3CYsJsyWLf4zTqi9
Steve
Actual unit
However,
Steve
