Here are the tools I have so far.
- soldering station 20-450 degrees
- solder
- electrical tape
- heatshrink
- multimeter
- PCB holder (has these elegator clips to hold PCB, seems like it won't be able to hold PCB when parts are in, maybe small PCB)
http://cgi.ebay.com.au/DUAL-ARM-PCB-Holder-Solder-Stand-with-Magnifier-T1460_W0QQitemZ140306044633QQcmdZViewItemQQptZAU_Hand_Tools?hash=item140306044633&_trksid=p3286.m20.l1116
- heat gun
- pcb laquer spray
- circuit board cleaner spray
(What other sprays should I get?)
- flourescent light
- magnifying glass
- cordless drill
- drill bits (what sizes are must haves?)
- screw driver set normal and for watch makers
- adjustable wrench small and large
- solder remover pump and this gold roll solder remover
- cutter
- short and long nose pliers
- tweezers
- scissors
- ruler
- hammer
- small desktop vice clamp, the claw only comes out like 50mm.
- cable ties
New Addition:
- Drill Press Vice 100mm
- Multicore X33-04 Isopropanol Flux and 40ml chemical dispenser.
- Static wrist strap.
Should I get these, if so what type or model:
- any brushes?
- what liquids should I get (flux or lubricant? If so, what?)
- glue, what type?
- oscilloscope (how important is this?)
- solder
- electrical tape
- heatshrink
- multimeter
- heat gun
- pcb laquer spray
- flourescent light
- magnifying glass
- cordless drill
- cutter
- tweezers
- scissors
- ruler
- hammer
- cable ties
New Addition:
- any brushes?
- glue, what type?
