hg_man
I'm looking at this schematic of PAIA's starved-plate tube mic pre:
http://www.paia.com/fantusch.gif
(Yes, it's a bad graphic!)
I can figure out most of what's what here, but what is this arrangement of 5 NOT gates with two resistors and a cap at the upper center? They feed into a voltage multiplier at upper right, that much I figured out. But what do they do? I'm betting that the resistors control the rate at which the cap charges and discharges, but I can't figure out how the NOT gates fit in.
Also, at center left there's an LED, which is the phantom power indicator. It's turned on by the phantom power bringing the NOT gate input high, which brings the output low, forming a voltage differential between Vcc and the output. But why bother? Why not just have the LED tapped into the phantom power so that when it's on, the LED turns on? Isolation? because the designer had an extra NOT gate handy?
Thanks for the help,
Alden
Alden
