Hi and thanks. I see on one build there ar two marked 473, looks like caps, and on another two resistors? What values would the resistors bea an if there are 473 caps, what voltage I wonder?
It's not impertinenet at all, but this perticular mic has a minimalistic layout guide, as far as I can see. Being a typically layout builder, I need a bit more detailed one, like the U67 or the Matador c12?
https://groupdiy.com/threads/neumann-vintage-u87-clone-build-thread.48030/
" Mouser Cart including all options ( 60M and 68M included also 2 different PN for 2K2 resistance)
important note :The BOM already contained alternate part number for the 2.2K (delete whatever is not available at the moment and also there is both the 60M and the 68M listed in there for you to decide both will work fine
just delete from your order the one you wont take, the 68M is less expensive !
