- Joined
- Jul 11, 2005
- Messages
- 132
I have made a small bipolar powersupply with 2 meanwell ac-dc modules (meanwell irm-20-24). the modules outputs are followed by dc-reguualtors to be able to bring down the the voltage to +-16V.
today I put the supply into its chassis with the rest of the pcbs and started measuring the outputs and the ac-input side before connecting the powersupply to the pcbs. all measures fine on the ac input side and also the dc output side. I then measured ac-voltage between PE chassis ground and 0V output of the powersupply, it showed 100V AC, the same goes for the other terminals, all showed the 100V AC. also when measuring between L and the DC output terminals I saw such high AC voltages.
the output of the smps powersupply is floating and the 0V is not connected with chassis or PE.
Why do I see these Voltages? what are they? cant the DC Output be floating? should I connect the signal ground to chassis/PE (I did for testing and the AC voltages are not there anymore.)?
thanks.
thanks.
