So the cap would go in parallel with the relay coil? I guess it wouldn't hurt to try. Maybe I should experiment and see if it really makes a difference.
I have heard of the Aromat/NAIS TQ2 relays before. Where could I get a data sheet or order them from? Mouser/Digikey??
Start with the diode alone, and if that clicks too much, experiment with capacitor value.
But note, that with capacitors across relay coils you run the risk of making a resonant circuit, that will actually sound like a cheap 80'es electronic drum when you switch it...! I had this once, and it took me too long to figure out what the h... was going on :shock:
[quote author="gyraf"]But note, that with capacitors across relay coils you run the risk of making a resonant circuit, that will actually sound like a cheap 80'es electronic drum when you switch it...! I had this once, and it took me too long to figure out what the h... was going on :shock: [/quote]
If you follow the usual practice of connecting a resistor and capacitor in series to form a "snubber", this should not be a problem. The resistor will damp out any resonance.
The cap or resistor-cap combination is optional; the diode is mandatory!
G5V-2 - this one is fairly relyable... opened my second spl vitalizer (some weeks ago) because the right channel didn't get the processed signal anymore in a mastering chain. Couldn't find the fault ad hoc. My brother in arm (musically and technically) had this relay in focus of being the a*hole since the a/b-ing with the vitalizer is the most "vital" part of using it at a mastering process and this gear is over 15 yrs old in heavy duty (1994/1995)...
(Since they had the problem in a peace of relatively new live gear a while ago at his venue.)
Since i didn't had one for replacement i tried alot (without much sense...) and found accidentially a 1Ohm resistor in the power section being rotten.
After problems with mechanical parts in nearly all old gear this relay seems to be pretty good and often found in solid gear.
