What`s the difference between a V71s & a V72s ???
I believe its that the v71 doesn't have the powesupply in the chassie where the v72 does Wil
Wilebee
Ollie.
Never nind, I will call him myself.
Be back with the info in two days. You watch.
from tab funkenwers web site quote:
The V71 was only made by Malotki and was a half size Danner module (without power supply) that incorporated the V72 circuit. The gain could be set with a resistor from 19 to 43 dB and needed an external N52 power supply
Wil
Darn, Wilebee! Scooped again.
From Ollie:
What is the difference between a V71S and V72S? Thanks!
There was no historic V71S, the V71 was a V72 without a power supply, so you
needed a very large power x-former to run them....
The new V71DI is a V72 without an input x-former for simple instrument
amplification, I changed the feedback to get a higher dynamic range for Bass
and Guitar...
Best regards,
Oliver
:grin: Good one Wilebee!
(w b?)
Oh. doh on me, Wile bee.
Lil slow today. someone must have swapped me out for decaf. :mad:
The new V71DI is a V72 without an input x-former for simple instrument amplification, I changed the feedback to get a higher dynamic range for Bass and Guitar...
Is it difficult to modify a historic V72 for DI use doing the above quoted without messing it up too much?
(edit begin) to be more precise, can I feed the grid of the first stage EF804 with my guitar signal directly, or will I need some input resistors for that?(edit end)
I use my V72 for bass, with a DI box in front of it, now I am racking it and was wondering if I should use a separate DI circuit (ss active or transformer) outside the unit or modify the V72.
Thanx for any suggestions...
