> a room to record acoustic guitar and vocals? I have a 12 ft by 9 ft room
So how does it sound, right now, when you sing and play acoustic guitar?
I suspect a room that small and hard will be "wonderfully supportive", a joy to sing/play in. That's good.
When you throw a mike in and listen somewhere else, it may be "too live" and "sound small". The large reverb, when reproduced in another space, confuses the ear, which can tell that there is a "phantom room" (the recording room) transplanted to the playback room.
So I would then throw enough thick soft fuzz (sleeping bags, overstuffed cloth sofas, or the fiberglas and foam panels made for the purpose) in there to take the reverberation down, but not eliminate it. Compare how the performer feels against how it sounds in the mix.
If the location is quiet and the weather is nice, opening the door and window will give you about 20 square feet of perfect absorption for free. That will bring the room average absorption down from about 0.98 to maybe 0.95, a small but probably audible change. If that change is in the right direction, but there is not enough quiet/nice time when you can leave door/window open, get about the same square feet of thick soft fuzz.
If doing baritone voice, bass guitar, drums: you will find some bass notes are over-emphasized. The bottom of an acoustic guitar may be in this range. Hanging sleeping bags 4"-8" out from the wall helps their bass absorption. Hanging the sleeping bags in the corners absorbs excess bass more than midrange; you can buy bass traps made for this use. But don't worry about it if you can't hear it in the room (or in the mix).
