jaymz168
Member
- Joined
- Aug 6, 2010
- Messages
- 15
Hi all, I got into Eurorack recently after years of resisting the GAS. Most of these Euro mixers have single ended outputs and you end up having to eat up space with modules to balance the outputs. So I'm planning to make a little tile thing that can sit inside the case and go between the module and the output jacks. Since I want to make this as small as possible I'm going to use SMT wherever I can and I'm trying to optimize the output protection diodes. I'm using THAT1646 output devices and they recommend 1N4004. Alternatively I've been looking at RS1B/D, BAT60 or even BAT160 dual common cathode.
Here's a screenshot to show the kind of dimensions I'm working with:
What's the part du jour for this at the moment? Any other suggestions? Thanks!
