Family Hoof
I've got a Triad FS24-500 mains transformer and no matter how I wire it it just seems to short the primary input. Before you jump to conclusions know that I had the schematic and wired it correctly first. No response! Only then did I try every other permutation. My 120AC from the wall is fine and balanced but when connected to the primary I get between 0 and 2V (shorting out, right? so the remaining ~2V is just the difference between + and - AC from wall) and at the secondary it never goes beyond 100mV or so.
This is brand new item! All I did before hooking it up was to solder some of the leads together (primary in parallel, secondary in series), and then I removed the connections to try other options. What could be wrong and why? Help!
