Hi!
I'm making another Reamp, this time with Cinemag CMLI-15-15B transformers, and i'm not sure where to connect it's shields. There are two between the windings and one outer (transformer case?).
On Cinemag datasheet it looks like they all should go to ground:
http://cinemag.biz/line_input/CMLI-15-15B.pdf (i have pcb version)
On Jensen's schematic for reamp outer goes to ground, the other goes to minus pole of the secondary:
http://www.jensen-transformers.com/as/as092.pdf
Can someone please explain me this a bit? Should they all go to ground?
I have another question; it's good to have jack connector insulated from chasis, but i couldn't find one localy. Is it a problem if i use non insulated and simply make ground point there instead on the input
Miha
Miha
