Dyonight said:
I'm powering 21 preamps with this and achieve stellar results but it is all in a huge 4U enclosure and I want to split all of them in 3 separate rack, so I'd like to get 3 separate power transformers and hope I'll be able to fit all this in each case without noise.
Putting a transformer close to sensitive equipment is always a challenge. Very often it requires additional magnetic shielding, which prompts the use of an enclosure for the xfmr, made out of thick steel and/or mu-metal.
I heard that R_Core tend to be quieter so that's why I'd like to try those and be sure I can find good quality ones.
R-core xfmrs, offer the possibility to have separate bobbins for the primary and secondary, which reduces capacitive coupling of interference present on the mains line. Toroidals, by construction, do not offer this possibility, but they can include an electrostatic shield; however, most off-the-shelf toroidal xfmrs do not include that.
OTOH, R-core types radiate more magnetic stray flux, which seems to be your Nr. 1 issue.
That said, if experienced builders think I won't get any benefits from using a R-Core tx, what would you recommend?
Have you considered using SMPS such as
https://www.digikey.com/product-detail/en/xp-power/DNR10US24/1470-1087-ND/4487468
or
https://www.digikey.com/product-detail/en/xp-power/ECL05US48-T/ECL05US48-T-ND/4476522
I've done just that for a 6-pack. Just to make sure, I added some filtering to the rails (See attachment). I used a DC/DC converter to derive 48V because the 48V SMPS was not available at the time.
https://www.digikey.com/products/en?keywords=XP%20POWER%20-%20JCD0624D24%20
In fact, even though they're actually available, I would still use a DC/DC converter, because SMPS do not work well under minimum load.
They have a version that delivers +/-15V at 1A, but does not exist in +/-24.
https://www.digikey.com/product-detail/en/xp-power/ECL30UD02-T/1470-1206-ND/4487587
