Where to get 220 M.ohm resistors?
RuudNL
Haule / The Netherlands
I am looking for some (through hole) 220 M.ohm resistors, 0,25 or 0,5 Watt.
I tried already Mouser, Digikey, RS Components, Farnell etc.
Of course I could put resistors in series, but I would prefer a single resistor...
Any ideas?
For me the 0.5 Watt isn't important. As long as the resistance is (about) 220 M.ohms!
The voltage in a microphone won't be higher than 60 Volts.
The 0.25/0.5 Watt was just an indication of the form factor.
DIY is the answer ;) :
This would not work very well for high value resistors. Even if you carefully cleaned the assembly, over time moisture, dust and grime would cause leakage currents significant enough to affect it's performance. And capacitance and inductance would be higher than that of a proper part.
Any ideas?
Mouser appears to have a wide selection of values in 100M to 1G range - carbon film, and not that expensive.
The only one at can find on the Mouser site that comes close is this one (250 M.):
588-MOX-200002506FE
But this evening I got information from someone who maybe can get the value I am looking for (220M) from Taiwan.
I don't have a problem to buy a couple of hundreds...
This seems strange to me. Using a 220 Mohm resistor in a circuit is somewhat dubious because it could easily be unreliable if it is not interfacing with a part that has similar impedance. It would be a bummer to buy $500 worth of resistors only to find out later that the circuit behaves strangely and should have used an alternative design. What is the circuit? Post a schematic.
