Thanks for that. I think the switches I am after are the mini ones as used in Soundcraft & DDARS online still list quite few Alps switches..... Alpine Push Button Switches | RS
Do they do push switches ? They don't seem to appear on their menu.
Yeah, you can find them in the shop, you'll have to scroll down a little bit.Do they do push switches ? They don't seem to appear on their menu.
Thanks for that Lee but I think these are Schadow switch size and not the miniture type I'm after.Yeah, you can find them in the shop, you'll have to scroll down a little bit.
https://www.blore-ed.com/shop?page=2
Alternatively, AML (Audio Maintenance) have similar switches which might be suitable.
http://www.audiomaintenance.com/acatalog/Push_Switches_-_PCB_Mount_.html
Thanks Ian, but I think these are Schadow switch sized & I am afte the miniture ones which are smaller.As Lee said, click on Blore Edwards Shop and scroll down or just go here:
SPUN Latching push switch | blore-edwards-ltd
Use Prev/Next to see other types they do.
I would be grateful if you could Cemal.Hi Rob,
I had bough some from Rapid a couple of years ago. So, I may have one or two. I'll check.
There's a couple of different sizes, the SPUN switches are the larger type, the SPUJ type are the miniature ones.Thanks for that Lee but I think these are Schadow switch size and not the miniture type I'm after.
Ah, Ok. Thanks for that info. Should be perfect.There's a couple of different sizes, the SPUN switches are the larger type, the SPUJ type are the miniature ones.
I spoke with Brett they have other configurations of the same switch available, just not on the website.AML has the 4 pole SPUJ switches, the price is better than Mouser but they have a £25 minimum order.
http://www.audiomaintenance.com/acatalog/AL-03-006_extended_info.html
RS also has them in stock for a better price than Mouser, and also without the £25 minimum order required for AML.
It says "DPDT" in the description at the top of the page, but the detailed description clarifies that "Stock number 758-2118 is a 4 pole Latching Straight switch".
https://uk.rs-online.com/web/p/push-button-switches/7582118
