Rocinante
I'm getting rid of some duplicates. So make an offer, but don't be ridiculous.
I take that back; be ridiculous
"Why be outraged when you can be outrageous." T Robbins.
Neutrik Rean collet knobs - $10 obo
C150H-09-R012 - I have 6 of these which are .125 inch 15mm -
C150H-09-R6 - I have 4 of these which are 6mm by 15 mm
There is also 10 white, blue, and gray caps that I will throw into the lot
Disclaimer: These are pretty nice soft touch collet knobs. Please read their datasheet here: [/url]http://www.mouser.com/catalog/specsheets/REAN_Page6.pdf[/url]
2 x Whistle Rock Audio ML12 partially stuffed boards. All caps, switches, and resistors are on there, just needs one stop at capi for the doa's, in and out xfmrs, pots and relays. I have the nice 4 rail WRA psu fully stuffed but calibrated at 24v but its not much work to switch it for 15-18 and ill gladly do it if asked nicely. Make an offer.
Pics.
Mnats 1176 rev d pcb with ratio and meter and input xfmr pcbs. - make offer
Five Fish X-12 with front panel- This is a single channel x-12 with a front panel via sticker done at five fish. It is fully operational using EA 2602 and 2503 input and output transformers. It was my very first mic pre kit and so also my learning board and so isn't my cleanest build but with that all said it works perfectly and is an awesome 312-ish preamp. It has the ic op amp but you it only takes a little effort to put a DOA in there. I hate to sell it but I just have too many API-ish mic pres and need to fund other projects.
This includes the x-12 mic pre and a Five Fish front panel with the sticker screens. So all you would need is a psu and toroidal (its like $80 at Five Fish) and a case (par metal width although I might have one laying around) and you would be set.
-Shoot me an offer-
Okay so now here is the random xfmr, knob, pot, switch, resistor, and cap, etc.. pile. Look carefully as there is pretty nice old mojo caps that are either used or NOS and NOS high watt resistors. I am using a bunch of these for an la2a or sta level point to point but I don't need them all. If you have a value you need hit me up. You pay shipping for the xfmrs but otherwise its on me as well. Most of this is FREE, some things are a few bucks that I will donate to the forum.
High watt resistors. From 1 to 25 watt. You tell me the value(s) you need I'll see if i got em and will send them to you.
Caps and resistors. Sprague, Cornell dublinier, etc...
Maybe you need some random xfmr and its here? You pay shipping and I'll send it to you. As you can see they are disgustingly large.
From a Bogen mixer amplifier. I believe the model numbers were C-35 and C-60.
From an ADD digitizer 4
Bogen
another set of knobs. D shaft. See Greg I can get all 12 of mine to float (compared to your 1 big one). No sightings though.
will add more
Natstovia!
Dylan
Pics.
-Shoot me an offer-
Bogen
will add more
Natstovia!
Dylan
