Such a common misunderstanding...and they also erroneously assume that this (small signal) output impedance is identical to driving capability.
the anode choke would be placed on the second stage, not the WCF
Which is a good reason to choose a high gm tube for such a stage. My preference is the 6922 (E88CC).
My understanding is that the designer actually didn't "design". He took parts of existing, tried and true schematics and put them together. I'm not dissing, I think he was concerned about making this product within time and money constraints.I have always liked this circuit. I was just wondering in the past few days why a similar solution hasn't been used in the Motown direct Amp we are discussing in another thread. The patent was published in 1944, in the following 20 years it should have had a good circulation.
Plate inductors are about increasing output voltage, when cath-followers are about increasing current output. One does not necessarily need both. It's usually one or the other.I like anode chokes myself too. But one thing to think about if you're then coupling to a White follower - or even a humble cathode follower - is the voltage swing capabilities of each stage. Your choke loaded anode will be able to swing almost double the H.T. supply voltage it's supplied with.
In order for your follower to swing the same amount of signal and preserve that headroom, it'll need twice the H.T. supply voltage that the anode choke has.
You could cap couple the White and then establish it's own middle DC bias point, but if that is run from the same H.T. voltage as the proceeding stage, you just lost half your voltage swing on the output stage and it has 6dB less headroom.
True, I think exactly the same as you!My understanding is that the designer actually didn't "design". He took parts of existing, tried and true schematics and put them together. I'm not dissing, I think he was concerned about making this product within time and money constraints.
Yes, we say: "the rice is cooked!"Sure, why not. There are gazillions of solutions and ways to do what that Motown amp did. Just pick any decent valve mic amp circuit that tickles yer fancy, rip out it's input transformer, install a suitable 1st grid leak of 2.2M (that's my usual 'go to' but season to taste if you need), wire in a 1/4" input jack... And "Robert's Your Live In Lover", "Bob's Your Uncle", "Etcetera" "Et Viola!".
This has always puzzled me. Making a decent anode choke that will carry dc and have a decent frequency response is pretty tough but quite possible. Why add a follower to lower the output impedance. Why not just add a secondary?Sure, the choke increases the valve's output voltage swing cabability, but It's not always the only reason I'd go for it though. The loadline becomes almost horizontal and the valve linearity goes up too.
And if we've just increased headroom and linearity by spending good money on a choke, then why not keep that benefit in hand by making sure our follower is able to swing the same amount of voltage while supplying the current we need for the outside world. Yes? No?
Just my own thoughts on what Max is proposing.
Any one of us on here could come up with really good implementations and, left to our own devices, they'd probably all be quite different but equally as good at the job.
To use only stock components? I've done it sometimes.This has always puzzled me. Making a decent anode choke that will carry dc and have a decent frequency response is pretty tough but quite possible. Why add a follower to lower the output impedance. Why not just add a secondary?
You know me, just trying to understand these things better.
Absolutely. The fun is in the discovery alright.Yep, me too Ian.
You know as much and probably more than I do so I'm probably not much help in that regard!
However, if I ever got to the point where I felt I understood most things, it'd probably take a good bit of the fun out of it all.
I was wondering if there was any particular engineering reason for doing it? The combination of plate choke followed by a capacitor coupled gapless transformer is common enough but pretty much all the designs like that I have come across are using pentodes. Maybe it is a pentode specific thing.
Neve's early class A transistor designs use a transformer to obtain both the double Vcc output swing plus some gain; but there is an option to have just an inductor if a balanced out is not required.
Going back further, Rupert used an EF86 with a plate transformer in one of his early tube mixers.
Which is a perfectly valid engineering decision.I've seen chokes used on triodes as well, by Neumann, for example.
having a transformer would load the stage differently than an anode choke. I would rather keep the voltage amplification separated from the output load, hence the WCF.
It might show my lack of understanding on how the WCF or a SRPP works but do you not run into Heater Cathode Insulation Voltage Breakdown voltage issue with either circuit if an ECC88 valve/tube is to be used?
