pucho812
Is there any reason why most opamps have a max operational voltage of +/-18vdc. I know there are some exceptions but they are fewer and fewer these days.
Learn something new daily. Yes very few go beyond that. Thanks jr.Physics... the typical maximum breakdown voltage for opamp silicon substrates is around 36V. Some modern op amps can handle more voltage.
For better reliability I never ran op amps much above +/- 15V
Is there something about 36V to pn junctions in general or is it really decided by the fabrication tech / tool chain?Physics... the typical maximum breakdown voltage for opamp silicon substrates is around 36V. Some modern op amps can handle more voltage.
IDK.... There certainly are discrete semiconductors with breakdown voltages many times that. There are even tricks that some IC makers use to allow parts of the IC to operate at higher voltages than the rest. Some early power amp chips used that trick.Is there something about 36V to pn junctions in general or is it really decided by the fabrication tech / tool chain?
Was that one of the reasons for the Exar 5532 ceramic package? It's max supply was +/-20v.IDK.... There certainly are discrete semiconductors with breakdown voltages many times that. There are even tricks that some IC makers use to allow parts of the IC to operate at higher voltages than the rest. Some early power amp chips used that trick.
That'll give slightly over +24dBu if the amp can run rail to rail, maybe chosen as a target?
Yes for premium prices you can get higher rail voltages. I stopped following new op amp development closely after they routinely became faster than audio (back in the mid 1970s). Over the decades I have used truckloads of TL07x and 553x op amps as being more than good enough for audio. For lower input noise or increased output current it is easy enough to hang a few discrete devices onto and around the GP op amps.fwiw I use opamps with high voltage rails eg +/-40V and higher on a daily basis.
See TI OPA445 and similar. These in SO8. Obvs heat dissipation can be an issue and the higher voltage types eg +/-90V have a thermal interface pad on the bottom that should be soldered to the negative rail. So awkward for diy and modding (I know this first hand).
But you won't get super low voltage noise Bipolar types in this range - they are FET and CMOS input types so low input bias current.
Going higher you can look at devices from APEX but they get very spendy
Exar definitely had it going on with their 5532/5534.Was that one of the reasons for the Exar 5532 ceramic package? It's max supply was +/-20v.
That was the best-sounding 5532 I ever used; I think I only have one left.
Years ago I used to have an MCI forum with Larry Lamoray, one of the designers of the MCI JH-500. One time, we were discussing exactly this topic. The first two revisions of the JH-500 used to have MCI-2002 op-amps, which were an Intersil rebranded high-voltage op-amp, as you mention. The consoles used to run at +/- 36V, but they had to lower the rails down to +/- 32V in subsequent production runs, because the 2002's were getting fried very often.To answer the original question affordable junction-isolated semiconductor processes determined the 30 to 36V supplies we use today. Many of the earlier HV op amps (HA-2645) required expensive dielectric isolation to break the 40V barrier.
The 5532 (still) has an absolute maximum supply voltage of +/-22V and can be run on +/-20V in PDIP.
The 5534 single (and many others including duals if used properly) can be bootstrapped to much higher supply voltages with external transistors as was done by MCI's "Swinging Op Amp."
For a voltage-boosted NE5534 to have much value it needs to be current-boosted too.
MCI Swinging Op Amp Ad dB Magazine January 1979.
References:
Bootstrapped Op Amp Articles - Pro Audio Design Forum
Voltage-Bootstrapped Current-Boosted NE5534 Swinging Op Amp Audio Line Driver - Pro Audio Design Forum
I first saw the swinging op amp in 1974. I built one as soon as I saw the Idea for Design in '74. I wrote:The design or idea—as Larry told me—came from an op-amp applications handbook, so it wasn't like they were inventing a revolutionary circuit.
I imagine they saw it in the Burr Brown book. Dogra is the first reference I've ever found for it. (Cited in earlier post.)The first installment, an Idea for Design published in 1974 by Surjan Dogra may be the grandaddy of all high voltage-bootstrapped designs.
It was republished and cited by Graeme in "Designing With Operational Amplifiers, Application Alternatives" in 1977.
Regarding the MCI-2002: about 15? years ago I found a replacement in Mouser for the 2002s, I don't remember how good it was in terms of performance, but it could handle the high-voltage rails. The original Intersil part could still be found NOS a few years ago (maybe still now?) on eBay and places like that. I bought several of them years ago (from Larry Lamoray himself) later to be sold faster than hot bread for about $30-40 USD a piece to the MCI community. The Signetics plastic 5534s are also fiercely sought after.I first saw the swinging op amp in 1974. I built one as soon as I saw the Idea for Design in '74. I wrote:
The PN5679/5681 plastic bootstrap transistors MCI later used to replace the metal 2N5679/2N5681 were incredibly failure-prone.
The JH-500C EQ section of the channel strip was an idea location to bake spit out of condensor mics. They did run hot and baked caps.
SSL used the HA-2645 HV op amp (originally Harris Semiconductor) as the 5 phase HV cathode driver for their plasma meters. I wonder what people use to replace them.
We explored this at length on Wayne's forum.I first saw the swinging op amp in 1974. I built one as soon as I saw the Idea for Design in '74. I wrote:
He provided a link to that thread at Wayne's forum a few posts ago.We explored this at length on Wayne's forum.
Back in the 70s I used a variant on that topology to refresh a hifi amp for my younger sister to play records through.
