I've built a point to point 6G15 '63 reverb in my "dev" chassis but didn't have a 6K6 tube, to get it up and running I used a Soviet 6P6S (6V6 is close) and a small 6V6 SE OT from and old '50s radio. All working but I find the 6P6S/SE OT can overdrive the spring unit when cranking the dwell knob (does sound good on guitar tho) but I'm sure there is a risk of blowing the winds on the transducer.
So... why not wind a low watt (2W should be enough) custom OT for matching the various old tubes I have in my stash I have no use for:
NOS 6005 made in USA = mil spec 6AQ5 but close to 6V6
NOS Mullard EL91
Mullard EL42
Mullard EF80 (might be good for 1W)
Mullard ECL80 (don't bother with the shared cathode triode section)
Mullard PCL83 (12.6v heater - also has a low µ triode)
Mullard ECL82 (bonus - includes 70 µ triode)
I have some iron to used from old SE OTs (radio pulls) and some small modern cores from 100v line audio transformers.
Will need to match to 8Ω for the tank input
See photo.
Doug
NOS Mullard EL91
Mullard EL42
See photo.
Doug
