A certain wire diameter does not have one fixed maximum current. The maximum current is chosen/calculated based on the core size and a temperature target. On a bigger core the wires will heat up more at a particular current than on a smaller core since convection is worse for inner layers and they are stacked higher. There are tables for differenct core sizes where you can find recommended current densities based on the temperature the transformer should be run at. So the bigger the core, the lower the recommeded current will be. It doesn't matter for your choke, but for a tube power transformer for example you would have the heater windings on the outside since they carry the biggest current. That way they cool better and can be run at a bit higher current density than the inner layers.Spencerleehorton said:So are you saying that if I use for instance 0.25mm gauge which can take 860ma of current that i should be using a gauge of wire that can take much less?
Would like to know a bit more about what you have said, as allowing for lower current, your saying that the current will only be 150ma.
I'm confused on this!!
