Wiring help
What is this device?
It looks like they want TS (mono) 1/4 inch connectors and PIN 3 is hot, which is weird in this day and age.
The female jack is a switch as well as a connector. When you insert the plug into it it flips the switch and breaks a connection which is what "switch opens" means.
I found the switchcraft 113EPCX. This would be the schematic?
    121.1 KB
