Mbira
Hi folks,
In the brave new world of SMD soldering, I mistakenly reversed one of the diodes on this synth module I'm building. It is right where the VEE voltage is coming in. I believe the diodes are there to protect against reversing the connector. (ha!) Would this destroy anything else in the circuit? I am having a difficult time troubleshooting this circuit. I have replaced the diode that I had swapped.
Attached is a screenshot of that area. I reversed D4. The full schematic for this can be seen here. I'm asking because I fixed the diode, but the filter still sounds pretty crappy-the frequency knob is letting a lot of low end through, and I'm getting some other strange behavior. http://mutable-instruments.net/static/schematics/Ripples-v40.pdf
EDIT: it looks like I am having an issue attaching a pic. The diodes are at the bottom left of the attached schematic...
