WTB Amphenol (?) Winchester (?) connector for Langevin AM16
Help Support GroupDIY:
isophase
lutece
Hello,
I am looking for Langevin AM16 preamp female connector for racking job.
What model/brand is it ? And where to buy?
Thank you
Jonathan
Whoops
Portugal
probably it would be really difficult to find.
Maybe it's easier to sold directly
good luck
Rob Flinn
Sussex, UK
Hello,
Thank you
Jonathan
Very difficult to find. But why would you solder directly on the pins, that's a really bad idea. If I have to do this I solder directly to the pcb or the back of the connector. That way if you everntually find a connector you haven't ruined what it's supposed to plug onto.
shabtek
midwest usa
one could possibly find a female contact that will bite on the pin and drill out a block of perspex to act a a spacer, basically make a custom connector/wiring harness
Rob Flinn
Sussex, UK
I tried that using female dsub pins, but it never really worked very well. Probably my fault. I was lucky enough to find some sockets but that was 15 years ago.
Whoops
Portugal
I never said or advised to solder directly on the Pins.
What I meant by soldering directly is to solder the wires directly to the PCB,
thant's what I would do in a pinch
Brian Roth
Salina Kansas
I racked four of those modules years ago but don't have much info re. the connectors. The client actually had mating connectors so I didn't worry about them.
A close exam of the OEM module connectors (magnifying glass for me! lol) might reveal some markings or part numbers. I'm pretty sure those were MIL spec parts back in the day.
Bri
Brian Roth
Salina Kansas
Those types of connectors are called "rack and panel". I found this catalog page from Winchester:
You'll have to dig around to match the dimensions of the plastic shell and pins. Series MRA or MRE are probably the correct series. The MRAC page has some MIL part number cross referencing. That's why I suggested taking a close look at the existing Langevin connector for any manufacturer markings.
Those were semi-standard connectors Back In Ye Olde Days and made by a number of different companies.
I did find some pix I shot when I racked up those four modules. The attached clearly shows two distinctly different connectors (supplied by client), which all fit.
Bri
