gemini86
All I did was tape the template to the work piece, center punch each hole, then leave the template on to drill the pilot holes and punch, then removed to drill the small holes, since the small bits don't usually have a long enough point to find the center punch mark without tearing up the template.
Ideally, I would get a 2 ton arbor press and make a fixture to hold the punch, so I don't need to drill pilots... but that's a big much for a few holes. (if I start doing them regularly, I'll invest)
