Hi, I have a Yamaha m1516 that seems to have an issue with the gain switches. If the switch is in a position for a while it doesn’t pass signal. If I blast it with a lot of level it will come back on, or if I exercise the switch a bunch it will work as well. As far as I can tell this is probably because there’s some dc on the switch causing excessive carbon build up. ? Sound like I’m on the right track?
If this is the case I’m curious which caps may be the first and most obvious culprits causing this issue. I’m a bit hesitant to do a full recap for many reasons but honestly I’m digging the sound so much right now I’d like to change as little as possible. .. but I’d also like switches that work every time haha.
I attached an input channel schematic if someone smarter than me has any interest in taking a look I would be super grateful!
