S Solomute Member Joined Oct 19, 2018 Messages 16 Apr 26, 2022 #1 I've built a few of these now and they perform very well in the field. Reply with any questions. Attachments 1651008546421.png 313 KB · Views: 52
V vintagelove Well-known member Joined Oct 26, 2013 Messages 147 Apr 26, 2022 #2 Solomute said: I've built a few of these now and they perform very well in the field. Reply with any questions. Click to expand... Greenhorn question here, what do you call that [{ looking transistor configuration? Thanks
S Solomute Member Joined Oct 19, 2018 Messages 16 Apr 26, 2022 #3 I think you're referring to the fact that the input transistors are in parallel. Paralleling transistors improves signal-to-noise ratio, because the signal out of the two transistors is correlated and the noise is not.
