3nity
SO i just had a chance to pass some audio yesterday on my LC25 and im very proud to say that i works like a charm.
Is there no calibration needed i assume?
No sir, no cal needed for these ;D3nity said:SO i just had a chance to pass some audio yesterday on my LC25 and im very proud to say that i works like a charm.
jsteiger said:All eight "PR's" are damping R's on the power rails. If one or more smoke look for issues below.
PR1 = +V for IC's A1-5 and then onto SW PCB so look for a short near R1 or D3.
PR2 = -V for IC's A1-5
PR3 = +V for DTO5
PR4 = -V for DTO5
PR5 = +V for A9
PR6 = -V for A9
PR7 = +V for A6-7
PR8 = -V for A6-7
For now, i've just PR2 who has smoke. Have you an idea? I have placed the opamps on pcb socket, it is ok?
Have you some value who can i Check? Can i put in the lunchbox for test, less PR2?
Sorry but i don't really understand your answer above.
jsteiger said:If PR2 smoked you have a short or problem on the -V rail that supplies the IC opamps A1 thru A5. Or maybe one of them is installed backwards? Or you have shorted the pins for C2. If not that you have a solder bridge that touches one of the #4 pins on one of the A1 thru A5 opamps.
Wiz said:I have a LC25 that I finished.... I could have sworn I checked everything was working by running sweeps.... but maybe I missed one.
My 12.8Khz band doesn't boost or cut.
Everything else works...
I have been over the board.. I am pretty sure everything is where it should be.
Any thoughts...
cheers
Wiz
Awesome Jeremy! Thanks for sharing!Fachjeremy said:Sound Great!!! Thanks a lot Jeff, now it's time to built a second... For stereo configuration.
https://www.youtube.com/watch?v=nTKqTsQJJgA
Yikes! Glad no harm was done.deadpoet said:Good to know that you can install a DTO5 upside down and apply power for about 2 minutes (while wondering why it passes no audio :) WITHOUT it burning up or getting harmed in any way.
Possibly a bad solder joint on the headers or could be on one or more of the vertical R's on the switch PCB.mysticmerlin said:Hi, just built 2 LC25's. One is working fine but the second one is like 10db down and none of the left hand switches work, the right hand column switches seem to work fine. Any ideas welcome. Thanks
Excellent!!mysticmerlin said:As usual you were right. I had a header that had a bad connection. Working fine now. Sounds great.
