Hi there!
I just finished my EQ and I thought about sharing with the community to keep this great project alive and up to date. It worked (mostly) flawless from the beggining (which has to be the greatest feel ever...). I do have a problem with the bypass LEDs, which I'll comment on later.
I want to reassure everybody trying to put this together that with correct parts and soldering, the project works. Most (if not all) of the doubts I came across while working on this were solved in this very thread. Some errors I had (like ordering switches with integrated LEDs, because I thought it would be cool to have lights go on when things were pushed
![Man facepalming :man_facepalming: 🤦♂️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f926-2642.png)
) were because I didn't took enough time to research by myself. So yes: read everything, several times, and if you can solder, you'll have a neat EQ in no time!
The BOM I used is the one on Gyraf's website. It is perfectly valid, but it does not reflect a couple of important aspects:
- The couple of resistors you have to change so you don't have a gain boost when engaging the EQ
- Electrolytic caps are rated at 16V, but you should use higher voltage caps (35V should be fine)
I got the PCBs and frontpanel from Pusherman (in the UK). Not very expensive, and the frontpanel is pretty great (it saved me a lot of trouble. I learned that drilling holes in steel is not very fun....). PCBs seem to match the layout on Gyraf's website and the components marked on the siilkscreen are correct.
For tantalum caps and the dual 100K neg log pots, I found that Tayda electronics was, by far, the best possible deal (Mouser didn't have the pots when I ordered most of the BOM, and you can find the Tantalums in ebay, but they are not as cheap...). I live in Spain, but Tayda's shipping fees are ridiculously cheap. I can't comment on the quality of the parts, because I'm a total noob, but they seem to do the work just fine and the sound is nice, so no problem for me
One of the "trickiest" part was getting the switches. You can find the suggested Alps in some places, but they are quite expensive. After my LED switches fiasco, I ended ordering some from Aliexpress, just to find when I soldered them that they were TOO high from the PCB and the board couldn't be mounted on the panel. Again, my fault for not taking the time to check and recheck everything. I ended ordering these:
https://es.aliexpress.com/item/32651661605.html?spm=a2g0s.9042311.0.0.55b363c0bO34tS
https://es.aliexpress.com/item/4000966504132.html?spm=a2g0s.9042311.0.0.55b363c0bO34tS
They fit perfectly on the PCB and they seem quite sturdy. Time will tell if I messed up, but so far, I think I'm good.
PSU is one of Volker's POSNEG supplies. Maybe it is a bit of a overkill for this project, but it's working great. BTW, I'm using +-15V, because in the LM833N datasheet the input voltage range is marked as 15v. I'm not totally sure if that's the maximum supply voltage range for the IC, but I didn't want to fry them all so I settled in 15V supply voltage.
One important thing with this project is to be very careful with shorted connections. There are a lot of very close solder pads, so when I finished soldering both PCBs I spent a while with a DMM checking the continuity was the same in all PCBs (asuming it would be difficult to bridge the same spot in two different PCBs). Checking with a magnifying glass could help as well, but checking continuity doesn't heart and I love the beeping sound
![Grimacing face :grimacing: 😬](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f62c.png)
When I was done with that ¡, I followed Magnus' list of procedures before inserting the ICs (mainly, checking all the voltages are correct and mostly important, that the ICs sockets were getting the correct supply voltages). I slapped the ICs in powered up and it was the best f@#!ng moment of 2021!! Something I put together almost from scratch sounds pretty great
After that, all was just a matter of wiring it all together and putting it in the enclosure (I got a 2u Adam Hall enclosure from thomman). There it was when I found that drilling steel is no fun
![Laugh :LOL: :LOL:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. It's not the best wiring in the world, but I think it could work. If any of you see any obvious mistakes, please let me know!. I didn't soldered yet pin 1 on the outputs to the enclosure (and I'm still not sure I have to do it....)
That Big fat ass wima cap is sitting on the downside of the PCB because, again, I didn't took my time to double check but I was getting... I did check voltage rating, capacitance, width, etc... But I didn't check how big it was, so I couldn't put two of them together...
On the next post I'll coment some little problems I'm having in hope any of you can shed some light on them
