Voyager10
Updated: see post #33 for more measurements
Good morning all!
I thought I'd share with you some measurements I've been making of various different JFETs, for use in impedance converter / amplifier applications in condenser mics. Specifically, how do the JFETs compare in the very widely-copied "FET amplifier + emitter follower" transformer-based design. RecordingHacks attributes this to the ADK A-51 originally (see http://recordinghacks.com/microphones/ADK/S-51) and it can be found in the MXL 2001 and V67 (https://groupdiy.com/threads/mxl.84887/), sE 2000 (https://groupdiy.com/threads/se-electronics.70694/) and relatives, Groove Tubes GT-55 (https://groupdiy.com/threads/groove-tubes.45261/) and many, many others.
I used the following circuit:
![FET test preamp.png FET test preamp.png](https://cdn.imagearchive.com/groupdiy/data/attachments/74/74091-9bb066d29e01879d8a41731fe7937589.jpg)
The core of the circuit is the FET itself, Q1, drain resistor R4 and source resistor R3 (which set the AC gain), and variable bias resistor R2+VR1, which set the DC operating point. Almost all the clones use R4=20K. R3 is usually in the range 2K2-4K7, I'm using 2K2 for the maximum gain, as this will emphasise differences between the FETs.
There's an input socket J1, and the board allows the input coupling capacitor C_IN and the FET itself to be easily changed. For simplicity, the circuit was powered from a bench PSU and I omitted the output transformer - the output goes directly to an audio interface (and/or scope) for measurement.
Here it is in its box:
![Mic test box.jpg Mic test box.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/74/74092-52197e9741549978149ae5e234d078be.jpg)
The FETs I had available were:
Next post: basic DC/AC measurements
Good morning all!
- 2N3189
- 2SK117-BL
- 2SK118-GR
- 2SK170-BL
- 2SK208-GR
- 2SK30A-GR
- BF244B
- J112
