DIY 19' 3 slots 500 series Rack
English Version***
For the design of the front panel I used: Front Panel Express Your Expert for Front Panels and Enclosures you can do a .fpd usable 'as it' for most of the industry.
for the PCB drawing : KiCad EDA free and great software/ the common file for doing PCB is Gerber (.Grb) that you can send to any PCB industry (JLCPCB, PCBway,...)
Et comment sont stabilisés les modules 500 : par leur fixation en façade + 15 pin à l'arrière uniquement ?
that's it !
Si je récapitule :
* achat frontpanel.de du rack 1U 19" : auriez-vous une réf à recommander ? je ne m'y retrouve pas sur son site
+ envoi à Frank du dossier 500Edge pour obtenir les panels avant et arrière prédécoupés
You have to send a mail to frontpanel (Frank) and ask him a invoice:
- NRG 1u case : Kopie von NRG CASE 1U (300mm Tiefe), 69,81 €
- you send him the 2 files in NRG_3X_500H folder (link to this thread) :::eek:n front panel I have add the thread for screw the 500 modules + hole for 3mm Led on the right.
I prefer not to add switch hole and frontpanel/case bracket hole as size and position can be specific.
- 1xIEC connector + 3x XLR (Male & Femelle)
https://shop.frontpanels.de/IEC-Connectorhttps://shop.frontpanels.de/XLR-female-connectorhttps://shop.frontpanels.de/XLR-male-connector
You can also add the L bracket (for top/bottom)
https://shop.frontpanels.de/navi.php?a=260
In my case I just use L profile aluminium bar that I find at Leroy merlin.
* achat du PN48PSU et du Oupiin 8706-30G00D à volker aka [silent art]
Yes, his mail on the white market.
BOM for the PN48PSU above on that thread
* achat du transformer
You need a CC 2x18v / 36v CT like:
https://www.reichelt.de/de/fr/transformateur-toro-dal-30-va-2-x-15-v-2-x-1-0-a-rkt-3015-p15275.htmlhttps://www.mouser.fr/ProductDetail/Triad-Magnetics/VPT36-1390?qs=wkKrz7WmEgM2EIrgD3Tzhw==
* achat des autres composants pour les 3 PCB 15pin, et des connecteurs XLR et cshuko
You need to order the 500 edge. it's that small PCB where you come solder the Oupiin (EDAC type) connector...
* assemblage des 3 PCB 15pin et autres connecteurs
* assemblage de l'alim
* finalisation du boitier (renforts + trous en front)
"In place of the Led a switch could be add with a small size one, but not so much space..."
=> j'ai l'impression qu'un petit switch à levier pourrait tenir à côté de la led
Yes,
yes,
Yes,
Not possible to put a Switch side to the LED, not enough place. but you can put a Switch on the other side... A Swicth on a side and the Led on the other Side pf the rack...
bonjour Matho
Pour le design de face avant j'utilise : Front Panel Express Your Expert for Front Panels and Enclosures qui sort un fichier .Fpd que la plupart des fabricants vont pouvoir utiliser tel quel...
Pour le dessin de PCB : KiCad EDA
le format de fichier conventionnel pour l'impression de PCB est Gerber. si tu as un fichier .Grb tu peux l'envoyer à n'importe quel fabricant de PCB (JLCPCB, PCBway,...).
oui c'est ça !
Tu envoi un mail à frontpanel.de (Frank) et tu lui demande un devis avec infos de paiement:
- NRG 1U Case : Kopie von NRG CASE 1U (300mm Tiefe), 69,81 €
- Tu lui envoi les 2 fichiers dans NRG_3x_500H
Je te le remet ici : ajout du filetage pour le montage des modules 500 + la led à droite.
je préfère ne pas ajouter le trou du Switch car le diamètre dépend du Switch que tu utilise. Pareil pour les trous/points de fixation entre le frontpanel et le boitier (entre le haut/bas du rack et la face avant pour renforcer...). mais c'est quand même nécessaire de mettre des renforts...
- 1x IEC connector + 3x XLR (male/femelle)
https://shop.frontpanels.de/IEC-Connectorhttps://shop.frontpanels.de/XLR-female-connectorhttps://shop.frontpanels.de/XLR-male-connector* achat des attaches frontpanel with top/bottom (je ne vois pas trop où trouver ces attaches)
https://shop.frontpanels.de/navi.php?a=260(perso, j'ai fait ça avec des équerre alu que tu trouve à Leroy Merlin... que j'ai taraudé, mais très pratique si pas équipé en bricolage)
oui, * achat du PN48PSU et du Oupiin 8706-30G00D à volker aka [silent art] --> tu trouve son contact dans le whiteMarket
Tu trouvera le BOM (liste composants) pour le PN48PSU un peu plus haut dans le fil de discussion...
oui, il te faut un CC 2x18v / 36v CT, genre:
*Il faut que tu fasse une commande de PCB pour les 500edge (le petit PCB sur lequel tu viens souder le OUpiin et le reste) /// je n'en ai plus en Rab et ne peut pas t'en dépanner...
--> fichier 500 edge dans le 1er post.
pour les fixer/tenir, j'ai utiliser une équerre alu...
* assemblage des 3 PCB 15pin et autres connecteurs === OUI
* assemblage de l'alim === OUI
* finalisation du boitier (renforts + trous en front) === OUI
---> pas possible à coté de la Led mais possible de l'autre côté :: d'un côté du rack tu met la led, de l'autre le Switch...
Ca peut se faire si vous etes pas pressé ! je fais ça sur mon "temps libre"...
Après, pas sûr que ça soit avantageux par rapport à un produit du commerce! Mais possible...
Envoyez moi un message pour en discuter si c'est ce que vous voulez...
0-0
FYI
Me : Oran.Outan spoke about 15 pin connectors, I have to check if 30 pin is ok for 500 series modules.
Volker : The Oupiin 8706-30G00D is a 30 pin connector (15 pins on each side) and is commonly used for 500 series modules.
yes, sorry !
Oupiin 8706-30G00D is a 30 pin card edge connector socket. There are 15 contact positions (2x rows of 15 pins)...
FYI. Here is the replacement reference proposed by Volker
CON-986-72-301002 / 30 Pin Card Edge Connector
TARIC Code: 85369010
@oran.outan c'est parti je me lance grâce à toi dans cette aventure ! j'espère revenir bientôt avec des photos finish
juste une précision : as-tu fraisé le front panel pour placer les vis d'équerre de renfort à fleur ou ce sont des vis sans tête ?
(la traduction semble imprécise)
just a point of clarification: did you countersink the front panel to fit the flush-mounted reinforcing screws, or are they grub screws?
Hey hey !
I'm about to build one myself and I wanted to post the mouser cart I made , I can't seem to find a BOM anywhere so I cross referenced a few threads and made this. Could anyone have a look and let me know if i'm missing anything?
Mouser doesn't currently stock LM337 or LM317 , any replacements ? I chose LM317T but I can't find a direct replacement for the 337
I will post the final mouser cart once it's verified :)
Mouser NoMfr. NoManufacturerCustomer NoDescription Order Qty.
71-RN60D-F-200RN60D2000FB14VishayMetal Film Resistors - Through Hole 1/4watt 200ohms 1% 100ppm2
279-YR1B2K37CCYR1B2K37CCTE ConnectivityMetal Film Resistors - Through Hole YR1 0.1% 2K372
594-K104M15X7RF53L2K104M15X7RF53L2VishayMultilayer Ceramic Capacitors MLCC - Leaded 0.1uF 50volts 20% X7R 2.5mm LS4
667-EEU-FR1V221EEU-FR1V221PanasonicAluminium Electrolytic Capacitors - Radial Leaded 35VDC 220uF 20% L/S=3.5mm2
863-1N4007G1N4007GonsemiRectifiers 1000V 1A Standard2
511-LM317TLM317TSTMicroelectronicsLinear Voltage Regulators 1.2-37V Adj Positive 1.5 Amp Output1
532-507302B00507302B00000GAavidHeat Sinks Channel Heat Sink for TO-220, Narrow, Horizontal/Vertical, 24 Degree C/W, Black2
568-NC3FDM3LBAG-1NC3FDM3LBAG-1NeutrikXLR Connectors 3P F RECEPT DL1 SER SODR CUPS BLK/SIL1
568-NC3MD-L-1-BNC3MD-L-B-1NeutrikXLR Connectors 3C MALE BLACK METAL SIL CONTACTS1
587-305-52-036305-036-520-202EDACStandard Card Edge Connectors 36P SOLDER TAIL 3.56mm ROW SPACE1
647-UVY1J101MPD1TDUVY1J101MPD1TDNichiconAluminium Electrolytic Capacitors - Radial Leaded 100uF 63 Volts 20%2
737-MS2A-GMS2A-GAdam TechHeaders & Wire Housings MINI SHUNT 2.0MM 2P GOLD2
571-2MM-HBS03VT02HTB2MM-HB-S03-VT-02-H-TBTE ConnectivityHeaders & Wire Housings 3P,2MM,BRK HDR,SRVT,2.8,0.76AU,TB2
Hi Info,
if you read the thread you will find all the info you need...
BOM for the PSU is on #9 post...
reference for the card edge and others thinks on the post up to yours...
PCB gerber and file for the rack on post #1/#2...
good luck on your build
0-0
Hi! back to business with 2 questions more, here :)
1. What do you think about using components stored for decades and/or cheap components for this PSU? e. g. Hitano capacitors instead of Nichicon.
2. And besides, 1/4watt 240ohms 5% rated to 1/2watt resistor : means it sizes 1/4 but can dissipate as 1/2?
